Can 4/0 4/0 4/0 2/0 AL SER cable be installed in thermal insulation and still be a code compliant install for a 200 amp residential service?
This would be the cable from the the exterior disconnect, thru the insulated attic space, and back down to the basement load center.
I recall a change in the code regarding SE cables but not certain what it was.
Thanks
Thanks
