c2500
- South Carolina
Ok,
Yesterday I installed 3 mats. One in one bathroom, 2 in another. Followed the instructions and made resistance readings. All were fine and within tolerance. Self leveling compound was poured over them. A rubber squeege was used to spread it, so no fear of a trowel nicking wires. This morning, two of the mats were fine, with identical measurements. The third mat had an increase of 11. Sun touch engineer said it was a kink. Removed the wiring to the point it hits the mat. Was getting very wild readings.
Then made a discovery. Part of the bathroom has no heated space below. It is the ceiling for a porch below. This area still appears wet relative to where the other matts are located. The portion of the mat that has conditioned space below is much dryer looking. When I walk (in socks due to newly finished floors) over the dry looking area, the reading is stable. When I walk over the damp looking area, the readings go haywire. Going as high as 100 or as low as 21. The end of the mat is located in this area.
Has anyone heard of this? There is no evidence of a kink because you can see the where the wire is through the leveling compound. The only odd variable is water. I think the tip may not have been sealed well and water is in the wire.
Also, there is no reading from black or white to ground.
Your thoughts?
c2500
Your thoughts?
c2500
