electricalstuff
New member
- mn
Trying to run NM cable in an accessible attic, 334.23 referenced me to article 320.23 which is about armored cables. Does that mean i have to run armored cables in the attic instead of NM cable? There's already NM cables running across the rafters in the attic installed by the previous owner. if running NM is still okay, would it be permissible to cut notches in the rafters and slide the NM cable in and use a steel plate to protect it instead of drilling holes in the rafters and having to rewire everything?
