M.D.
- Massachusetts
I’ve got a heat system with a 6zone control relay for zone valves they added a cooling system completely separate system .I installed a Honeywell heat / cool thermostat removed the jumper connected Red from relay to Rh and White from relay to W of T-stat base. Connected the air handler control wires properly and have checked them numerous times . The air handler has not been energized yet. I snapped in the thermostat switched it to heat turned it way up to check the heat side .. blew the 500 Ma fuse .. checked and rechecked wires replaced fuse , same result only this time I was watching, it glowed and blew out . Connect it back to the old t87 runs fine . 25 volts at R.W. This is the relay I don’t have the Honeywell part number but I’ve talked to them twice to no avail .. anyone got any thoughts?
