geoffgelectric
- ventura ca
Hey guys,
I don’t post too often. I’m more of a lurker but I appreciate all the info and knowledge on here big time.
Hopefully you guys can provide some insight to what might be happening on a job I just finished. Im all out of ideas and or reasons.
Just finished a new single family 12k sq ft build here in Los Angeles. 400amp main with 1 - 200amp sub and 2- 100amp subs and 1 - 125a Infratech control panel for 4-6000w 220v Infratech heaters which is tapped off the 200amp sub.
Owner just moved in and I got the call that when they turn the heaters on and set them at any setting other than 100 percent on the analog thermostat control that all the lights in the house flicker. When the control is set to 100 percent there is no flicker. ALSO… the NEIGHBORS LIGHTS flicker as well..
Now the POCO (LADWP) has come out and run their tests and the owner said it came back normal .. (I’m not sure if I fully believe it but I can’t go up the pole and test their transformer)
I oversized my feeders to the 200amp sub and I ran 1awg to the Infratech 125amp control panel which is only 2’ from the 200amp sub anyway. I spoke with Infratech 5 times already and they claim it’s a POCO issue.
Has anyone here experienced anything like this with Infratech or any other large load on a new build?
Any advice or knowledge is greatly appreciated. I’m at my wits end.
