I have a transformer feeding a C.T. can then to the main panel with the first point of disconnect. It is a 120/208 system. With 350kcmil feeders my main grounding electrode conductor connected to the cold water pipe is a 1/O wire, the supplimental ground is a #6 copper. My problem is what is the best way to ground the system right now as it sits between my C.T. can I have my three phase conductors and my neutral. In the C.T. everything is bonded together. Something to me does not seem right with the install. I think in my mind that if the main ground and the ground rod were connected through the panel instead of the C.T. and bonded only at that point with the neutal. Then bring an additional #6 from the panel back to the C.T. can to ground it? Or Does it have to be larger? I would really appreciate the help thanks in advance.
