southernboys
hey guys just got my wish. My boss handed me a job to run bad thing abot it is another electrician started the job. pulled all of the wires. Ive already noticed several problems on this job. starting with the dishwasher and dryer on the sa ckt. normally I pull a seperate homerun for these two. hit the switch for disposal and feed dw hot. can I tap off a switch for lights to feed these apliances. the bedroom switches were tied in with hallway switches prints are marked Job is to be wired to 99 code does this give me a loophole to the ark fault code? where would you guys begin this job at as Im pressed for time but have to catch any and all possible code violations. inspector has passed rough suposedly before I arived on job are these items listed above likely to be caught on rough or trim. I know what my boss is going to tell me not worry about these items but if I have enough of you guys backing my pov it would help my cause thanks. one other code queston is can I have more than 2 sa ckts ie a seperate one fot the dining room thanks
