Hi can any one help
DSC!@#
New User
Loretto, Ontario, Canada
Welder, Metal fab.
I just bought a 2-pole 240 Volt 200 amp 3-wire fused disconnect to put in a new garage. I will be getting 200 amp service and this will be my disconnect. The fuses that came in it are both 200 Amp each...... I thought the fuses would be 100 Amps each equaling 200 amps total since its a 200 Amp disconnect. am i right or wrong???
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
