shockingdave
- Dayton, TN
I have a disconnect with a two pole configuration, and hi-leg entering the disconnect from a seperate conduit, passing through the disconnect and traveling into another pipe to a motor control using the power from the disconnect. All three wires travel in the same pipe to the motor control. I am not certain, but I believe this would fall under two powers in the same box without the same disconnect and I am suggesting a rewire placing the hi-leg in the same pipe with the other wires, and changing the disconnect to a three pole. Is this correct, or can I leave the hi-leg in the original pipe and just change the disconnect?
