rwade0700
- Albany, NY
- Electrical Contractor
A local electrician has a non-conventional way of dealing with HID lighting when ballast replacement is necessary. In particular he had a 250 watt HPS flood fixture that needed a ballast and lamp replacement. Instead of removing and replacing the components he just gutted the fixture, ran line voltage to the socket and installed a $25.00, 250 watt equivalent compact fluorescent lamp. This sounds like a quick and inexpensive way out ,but I wonder about lamp life in an enclosed fixture, possible temperature problems or how the light distribution patterns may be affected using this type of lamp VS the intended HID lamp matched to the photometrics of the luminaire?
