Standard HID Testing Equipment - abridged
HID Assembly / Component Testing Equipment:
HPS - upto 150W Medium base screwshell lamp (55 volt lamps):
* Reactor / Autotransformer ("Ballast") output Tester = 120 VAC Incandescent Lamp (anything in the 25 to 100 watt range will work),
* Capacitor Tester: Analog Multimeter - scalable for at least Rx100K Ohm range,
* Ignitor Tester: (1) - Oscilloscope capable for > 3.5KV input pulses, (2) Known-Good Ignitor.
HPS - 150W and higher Mogul base screwshell lamps (100 Volt lamps):
* Ballast output Tester: Mercury Vapor lamp of equal wattage,
(Capacitor and Ignitor Testers same as above).
Mercury Vapor + Probe Start Metal Halide
* Ballast Testing:
(1) 0-600 Volt Voltmeter (Open Circuit Voltage range = 200 - 350 volts)
(2) Clamp type Ammeter - True RMS or basic Averaging is OK (Short Circuit Ampere load from Ballast = 1.0 Amps for 100 Watt lamp Ballasts, to apx. 4.5 Amps for 400 Watt lamp Ballasts).
* Capacitor Testing: Analog Multimeter - scalable for at least Rx100K Ohm range,
*** For Pulse-Start Metal Halide lamp Ballastry - Ignitor Tester:
LPS
* Ballast Testing:
(1) 0-1000 Volt Voltmeter (Open Circuit Voltage range = 500 - 685 volts)
(2) Clamp type Ammeter - True RMS or basic Averaging is OK (Short Circuit Ampere load from Ballast = 1.0 Amps for 35 Watt lamp Ballasts, to apx. 3.0 Amps for 180 Watt lamp Ballasts).
* Capacitor Testing: Analog Multimeter - scalable for at least Rx100K Ohm range.
Scott35
