TCMind
- Lowell, Michigan
First off right up front, I am NOT an electrician (I am a fire suppression designer in detection & control, low voltage), but I do have a desire to understand what and why on my salon equipment. For my "after hours" job, my wife and I have a couple tanning salons. We had a tanning bed replaced and I have a couple of questions on the voltage and amperage of the new tanning bed.
The existing service to the new bed is as follows;
Single phase, 100 amp circuit breaker feeding (2) 3 AWG THHN along with a 6 AWG THHN ground. Approximately 60' to a 100 amp disconnect in the room with 100 amp fuses on each leg. From there, another 30' to the contactors in the bed.
Voltage is: 248VAC
The tanning bed (from the name tag);
Power Input: 19 Kw, Voltage: 220, Cycle: 60 Hz, Power Factor: 90%
Upon startup of the tanning bed;
The temperature of the fuses were: 71.5 degrees F
Inrush is 160 amps!
Voltage (after about 30 sec) was 241 VAC
After 1 minute the amperage settled in at 107 amps.
4 Minutes into the session, fuses were at 99 degrees and climbing.
Not feeling to "comfy", I shut it down. Now for the questions and understanding. Manufacturer says 100 amp needed for single phase, and #3 will work. He also states, that these beds are inductive systems, therefore as the voltage increases, so will the amperage draw.
1. Is a #3 the right conductor size? 2. If I have a buck-booster installed, I know it will help with the voltage, but will it help with the amperage?
Any comments on why we are getting such high amperage and helping me understand would be greatly appreciated.
Thanks, TC
Voltage is: 248VAC
Inrush is 160 amps!
Thanks, TC
