nuckythompson
- Nova Scotia
- Electrical
I have a two source bus (one normal utility supply, and a generator supply). This bus has various motors on it. When I transfer the bus to the generator supply, the motors on the circuit draw higher amps. Seems to run fine on the normal source but motor currents ramp up when the generator is supplying the load. Any ideas why this is? Voltage readings show same bus voltage no matter the source.
Thank you.
Thank you.
