Good Morning,
A few questions on High Bay Flourescent lighting, typically found in commercial, industrial, and wharehouse environments. 25 to 35 feet height mount.
1. T5 or T8 Electronic ballasts, is one superior to the other at this height?
2. Is Harmonic Distortion a problem? Are their guidelines concerning the lighting load vs. capacity of the service that can estimate the THD?
3. If you had a 480V 3P 3W service, what supply voltage would you utilize? 480V 1P, 277V 1P, or 120V 1P.
I understand the wiring advantage with the 480V 1P, however does this limit the fixtures available and the increased price of ancillary equipment (switches, contactors, breakers, etc.).
277V would require an isolation transformer, which may not be a bad idea if THD is an issue. And, from the little I've seen, most ballasts are 120-277V.
4. Is there a light fixture height mounting restriction in the NEC, based on the supply voltage?
Alot of questions, any advice is truly appreciated.
