georgeswe
- The Republic of Southern California
Just wanted to see if anyone has ever hooked up Hi-bay fixtures directly to a J-box using the fixture cord provided by the manufacturer. Have done them where we installed Cord caps and recepticals when they are spec'ed. Usually we will use 3/4 Ridgid nipples into a swivel 4' cover. However these are the heaviest Hi-Bays I have ever seen and I don't trust the Nipple and the #8 4S box screws (the fixtures have solid glass reflectors probably 45 LBs. each no to mention the balaast weight. So i have to install a hook and use the #14-3 cord from the fixture. In this case the Receptacle in the ceiling are not speced and I just wanted to know if there was a code issue of making up directly to a junction box. Have had issues with using SO cord to arial drop to equipment off a gutter, didn't know if it also might apply here because this is a permanent installation.
