I have a high delta 3 phase 240/120V main panel rated feeding a tenant to be retrofited (pole mounted type transformer outside). There is no loads on the panel that are useing the 3 poles. Only legs A and C are being used for single and doubles poles. Leg B (high leg) is not being used which i understand why. My question, does the imbalance cause an issue? Does the utility typically care? and for the retorifit should i possibly reconfigure to 240/120 single phase or 208/120 3 phase? Thanks!
