Neither. The total power available will depend on the mix of 120/20 and three phase loads as well as whether the service transformers are same size.
If all you are concerned about is the load the OCPD will allow, the max would be with fully balanced three phase after adding in the 120/240 load.
Your first number.
If the bulk of the load is A to ,C, then the second number.
