starsandstripes
- SE Michigan
On a 3 phase 4 wire delta system I have the expected voltage of 208 from neutral to the high leg. Phase to phase all read 240 volts. A and C phase both read 120 volts to ground. B phase, the high leg reads 130 volts to ground. Does this mean the neutral is not bonded to the ground? if so what are possible problems with this? Thanks for your comments.
