electrofelon
 - Cherry Valley NY, Seattle, WA
 - Electrician
Hey guys, I have a lab I need to provide and install lighting for.  Owner wants recessed.  We typically install about 85-90 lumens per SQ foot for these spaces.  The framing is 16" OC, so I am looking at maybe an 80" pattern which puts me at 3500-4000 lumens per fixture.   I'm not dead set on that 80", but I don't want to install 3.74 zillion fixtures either.  Here are a couple products I am looking at:
					www.1000bulbs.com
					www.superbrightleds.com
Any opinions on these or any other ideas?
			Buy 3844 Lumen Max 40W Max Wattage and Color Se | 1000Bulbs | 1000Bulbs.com
Select the perfect color, brightness, and accessories with this PLT PremiumSpec LED downlight. Go to 1000Bulbs.com for more housing-free downlights!
				8" LED Commercial Recessed Downlight - Selectable CCT - Selectable Wattage - Dimmable - Up to 3,960 Lumens
The 8" LED commercial recessed downlight is a versatile lighting solution for commercial and residential spaces. The fixture has two slide switches; one selects from five CCT options and one from three wattage options. Spring clips allow for easy installation in commercial downlight frames. The...
