Raymondrestrepo@gmail.com
- Miami FL
2014 nec... All 3 phase systems with one phase being different (214 nominal to ground) shall terminate the varying leg to phase c at start of system(first means of disc.) I came across it in Miami at an animal hospital. When your high leg is on the c phase coming out of the meter going into a new disconnect should it stay on the c phase all the way until the load ? Or should you come out if meter c phase and then on line place on b phase and load b phase ?
