in a HRG system if I understand you place a resistor in the neutral to allow for reduced ground fault current to flow allowing continunity of service until the fault can be located (using a pulsing contactor) and repaired, my question is if you have a HRG system feeding a delta-wye transformer the primary of the transformer is seeing 277V per phase upon a ground fault the phase to phase voltage is increased to 480V? if that is the case dosent this effect the seconday voltage based on the turns in the Xfmr??
