Which is upstream: MCCB or bus bars?Can I use 10k rated MCCB with 6k rated busbars?
I don't know that I'm qualified to answer and I don't normally post where TMHS steps, but it seems to me that as long as you are installing a breaker with a greater AIC rating there would be no problem unless it alters some critical downstream numbers.
In simple terms it appears to me to be the same as replacing a 240v switch with a 600v on a 240 system but what do I know![]()
