ghostbuster
- Great White North
My customer has a 3 phase U.P.S. system.On the 480 volt delta input side,the phase currents are approx. 40 amps balanced on all 3 phases.The ground current on the 480 volt input side is approx. 5 amps.The U.P.S. supplier has performed a field investigation and claims this 5 amps of ground current is normal.They claim this current is from their filtering capacitors connected phase to ground on the 480 volt delta input side.This 5 amps of ground current appears to be extremely high.I am also concerned it may cause other problems in the overall electrical system at this site.
