Merry christmas to all,does the NEC allow high voltage and low voltage to be in the same manhole? also if both run under ground what is the minimum distance apart that they should be.
725.136 Separation from Electric Light, Power, Class 1, Non?Power-Limited Fire Alarm Circuit Conductors, and Medium-Power Network-Powered Broadband Communications Cables.
760.136 Separation from Electric Light, Power, Class 1, NPLFA, and Medium-Power Network-Powered Broadband Communications Circuit Conductors.
