overkill94
- California
I did an inspection on an amplifier that steps up the voltage from 220 V to 4200 Volts AC which is rectified to DC immediately after being stepped up. To connect the secondary of the transformer to the rectifier, they're using AWM style 3239 (http://iq.ul.com/awm/stylepage.aspx?Style=3239) which shows that it's rated for maximum 60kV DC. I flagged it as a discrepancy since the style page seems to indicate that it should only be used in DC applications, otherwise they would've just said 60kV without the "DC" qualifier. Is this the correct interpretation or should all conductors be assumed to handle AC and DC voltages?
