timm333
- Minneapolis, MN
- Electrical Design Engineer
[FONT=.SF UI Text][FONT=.SFUIText]I'm just trying to figure out that why is the ground continuity conductor not required when the metallic sheaths of high voltage cables are cross bonded. The total induced voltage is zero when the sheaths are cross bonded, but how does it relate to the fact that ground continuity conductor is not required? [/FONT][/FONT]
[FONT=.SF UI Text][FONT=.SFUIText][/FONT]
[/FONT]
[FONT=.SF UI Text][FONT=.SFUIText]Also the ground continuity conductor is required when the sheaths of high voltage cables are single point bonded, and the purpose of this conductor is to bring the fault current back to the source. But this conductor is insulated and is connected to the ground only on the two ends of the cables. So if, for examine, there is a fault at the center of the cable, then how will the fault current make its way through the ground continuity conductor? Thanks for help![/FONT][/FONT]
[/FONT]
