sokkerdude
- Arkansas
We have just installed the conduit system for the primary to a 750 KVA pad mount transformer. It was 3- 4 inch PVC with rigid steel long sweep 90's. The utility company has pulled 1 - 25 KV cable in each conduit. The primary voltage is 22 KV. My question is that not the same as us putting only one phase in a conduit and with rigid steel 90 ? If it is, will the primary wires be subject to heating or is there something about 25 KV wire that would keep it from heating. Thank you
