High Voltage Shrink Tube
PSM007
Farmington, NY
Hello,
I have a high voltage coaxial cable rated for 10Kvdc that has a pigtail on one end.
I can't find shrink tube that is rated for 10kvdc. Does anyone have any ideas on
on what I can use to cover the wire when I place my HV connectors on them?
This coaxial cable will be connected to a high voltage power supply
Thanks.
Tony S
You’ll need more than one HS tube. Where the screen ends a stress relief tube is applied before finally sealing with an overall tube.
BTW that’s the condensed version of terminating MV cable :huh:
I would suggest Thorn and Derek but they are UK suppliers. Any Raychem supplier should be able to help.
