Fred B
- Upstate, NY
- Electrician
Customer has purchased an electric boat that requires an EV charger 50Amps. Charger cord limited from mfg specs to 13ft and dock mounted charger pedestal. Dock is a floating dock that needs to be at least 40ft from shore for boat to approach. Dock is sectional at 10ft intervals and needs to be removed seasonally, so the electrical supply needs to be able to be removable and water tight. Looking for the possibility of wiring each section independently with a flexible disconnecting means between each section, disconnects would need to be watertight. Anyone have experience with this sort of installation or suggestion as to products that would work?
Additionally the distribution panel needs to be a distance away to get above the seasonal spring flood elevation. Historically has a flood elevation of 5ft above normal lakes datum plane.
