Can anyone tell me if NEC has any specs on installing a sump pump in a 13,800 pull well?
W wayneh Member Location Kentucky Mar 24, 2003 #1 Can anyone tell me if NEC has any specs on installing a sump pump in a 13,800 pull well?
tom baker First Chief Moderator & NEC Expert Staff member Location Bremerton, Washington Occupation Master Electrician Mar 24, 2003 #2 Re: high voltage well sump pump Is the installation under the scope of the NEC or NESC?
W wayneh Member Location Kentucky Mar 24, 2003 #3 Re: high voltage well sump pump Originally posted by tom baker: Is the installation under the scope of the NEC or NESC? Click to expand...
W wayneh Member Location Kentucky Mar 24, 2003 #4 Re: high voltage well sump pump I am not sure.I am currently looking in OSHA 1910.272 but other than working distances I have found no guidance yet.
W wayneh Member Location Kentucky Mar 24, 2003 #5 Re: high voltage well sump pump Originally posted by wayneh: Originally posted by tom baker: Is the installation under the scope of the NEC or NESC? Click to expand... Click to expand...
W wayneh Member Location Kentucky Mar 24, 2003 #6 Re: high voltage well sump pump Mistake, OSHA 1910.269
