Hilti shots vs. shields?
Depends on what I'm hanging...
For small stuff like straps screws and anchors work great. For fixtures or anything else that moves, I like to Hilti them...then again, I'd hilti boxes in if the boss would let me :)
You can hilti a box to the ceiling! I'm not going to say it correctly but I like the "Hilti Dart", your basic nail point with quarter twenty threads at the other end. This is more expensive than just a nail and a washer. This "Dart" also enables other fastening methods, like using threaded rods and a rod coupling for suspension off them. The price of the dart is between a the price of a nail washer and their 1/4" or 3/8" rod hanger's.
Always use the correct load for you shot, and remember shooting into new concrete pours are more brittle as opposed to aged material. Test firing is also a good thing, JMO. Remember also that concrete firms up in thirty days, it doesn’t cure for twenty years.
I didn't realize that you said plastic screws, nope I can only recall only ever shooting or drilling for a lead set pin or for a lead anchor and the choices seem to be regional and varied at best.
There are also Tapcons and the like. These actually screw into the concrete thus forming a better connection than pure friction. Also they are removeable which is better than Hilti nails.
Now the Hilti dart seems to be removeable also. Then it becomes a matter of cost and noise.
The plastic anchors can be pulled out with a claw hammer. Some people don't understand the concept of screws and screwdrivers. :-?
~Peter
Personally I don?t care for Lead Anchors. In a fire Lead has a low melting point. Though I have installed them in the past.
Hilti shots can be quick for the right application. I like the nail-in anchor as opposed to a plastic anchor.
My two cents
JJ
