Fulthrotl
~Autocorrect is My Worst Enema.~
- E
i gotta customer who does testing of food processing equipment,
and needs to test 480 volt motors from 50 to 100 HP.
he has been slamming them across the line with a non fused disconnect,
backed up by a breaker.... you know, one of those plastic hubbell
disconnects made for wet locations...
anyway, it blew off the wall, tripping the breaker, finally. some days
are like that, y'know? now, he's a little more gun shy about slamming
in a 100 hp motor with a disconnect.
a couple solutions are:
soft start
or
a fused disconnect, a variety of fuse sizes, with appropriate reducers,
downstream from a 100 hp contactor, with a limit switch on the
disconnect door to disable the contactor when the door is opened
for fuse changing.
or
a VFD, with some programmed setpoints for different motors... just
pick the motor you are going to use with a rotary switch, and hook
it up.
a 100 hp. VFD from allen bradley is about $11,000, so that's not gonna
fly well...
anybody here got ideas for something like this?
thanks...
randy
soft start
or
for fuse changing.
or
it up.
fly well...
thanks...
randy
