powerplay
- In front of a computer.
In an Outdoor HO Sign, there are two F64 HO T12 tubes and two F24 HO T12 tubes, totaling just over 14' in Tubes. The Electrical Supplier ordered an 1 or 2 Tube Sign Ballast minimum 4' to 16'. They say the Ballast depends on the length of Tubes in feet, but if the minimum is 4', would the fact there are 4 tubes, two of which are only 24" cause it to burn out prematurely? I was informer that an Ballast with a minimum length of Tubes greater than the length of tubes being used would also burn out the Ballast by 2 Electrical Suppliers.
