Good afternoon,
I would like to know if wiring an HOA selector switch through a PLC is acceptable as disconnecting means for a motor (NEC section 430.102). The logic is the following: To connect the "Hand" and "Auto" signals to the PLC terminal as an inputs. Whenever the selector switch is in the Hand position, the PLC would send an output (DO) to turn on the motor. Whenever it is in Auto, the PLC would automatically turn On and Off the motor depending on the logic. When it is in the Off position, the PLC would turn off the motor. Technically is the same thing but things are not hardwired.
Thank you for your advise.
Regards,
Daniel
Regards,
Daniel
