Alwayslearningelec
- NJ
- Estimator
A transformer with a delta secondary would either be ungrounded ( requiring ground detectors) or corner grounded (drives often aren't comparable with either) whereas a wye secondary (470Y/277) avoids those problems. If you have a 208 primary you are normally better off with a step-up delta, wye transformer
Thanks...geez my brain hurts. Corner grounded, delta/wye!!
As stated keep it simple, just buy the correct step up transformer, Delta/Wye 208-480Y/277.Thanks...geez my brain hurts. Corner grounded, delta/wye!!
And they are relatively easy to get.As stated keep it simple, just buy the correct step up transformer, Delta/Wye 208-480Y/277.
