With reference to NEC section 610:31/32:
I have a situation where an electric hoist & trolley is being installed for maintenance of equipment in a Cl. II, Div. 1, Gr.F area. The hoist is powered from a 480 VAC feeder circuit breaker in a MCC located out of sight, in an electrical room several hundred feet from the hoist & trolley. The hoist is mounted on an I-beam from the ceiling (15' high) and includes a flexible cable festoon to allow movement of the hoist by the trolley along the beam. The hoist is fed by a single 480 VAC feed and internally the hoist has been supplied with motor starters for each of the hoist and trolley motors, which are controlled by a pushbutton pendant station hanging down from the hoist.
Is a local disconnect switch required for the hoist and trolley, even though the plant may have a lockout/taggout procedure and can shut-off power via the CB at the MCC?
If a local disconnect switch is required, would it be required to be located at the ground level, within sight of the hoist, where it would be readily accessible? Or should it be part of the hoist & trolley electrical enclosure itself or installed just prior to the festoon cable, both at ceiling height?
