NolaTigaBait
- New Orleans,LA
anyone know if they make an electrician hole saw set that cuts brick?
If it's a small hole 3/4" or 1" I just use a hammer drill. You can do that with bigger holes too just drill more holes. Our if you have access to a core drill ( more expensive ) you can drill exactly what ever size you.
I concur on the core drill. It's basically a masonry hole-saw. You will need one with a shank that matches your rotary hammer; an SDS-Max for my Bosch.
I mad a 6" hole in an old 3-courses-thick brick wall for a customer. The resultant hole is smooth and round. Rent one, and the drill for it if you don't already have one.
Added:
Some of these may be larger than you need, but . . .
Those are diamond bits. These are carbide - the kind I have:
For the bulldog SDS you will want a "Dry core" bit, they have teeth.
The ones in Larry's pictures are "Wet core" bits and require a different tool then a bulldog.
The ones in the second picture are the dry, percussion type.For the bulldog SDS you will want a "Dry core" bit, they have teeth.
For those sizes we would just use the solid-core type of bit.really, all that i would want it to fit is 1/2, 3/4, or even 1 LB's and the like...you think lowes or hd would have this? or is this more of a specialty tool?
That must be the dreaded protected image I sto, I mean, borrowed.The second picture is the dreaded red X
Try this one:
yeah, ive got the bosch bulldog sds...ill try the masonary hole saw
