Unless a piece of paper with a PE stamp on it says it's OK, and how to do it.
Common dimensional lumber usually has some "headroom" in certain places, and the building code take that into account; e.g., there's little shear in a horizontal beam in the middle third, so the codes let you drill holes in that region in floor joists. OTOH, they experience alot of compression on the top edge and tension on the bottom, so notches here are a no-no.
Each member in a truss is either in tension or compression, are typically designed to minimize material, and usually don't have much "headroom". You have to run the engineering analysis to determine if reducing the cross-section of an a particular member (drilling) is OK. The good news is that it's probably possible to design a repar procedure, given that the forces on each member are either simple tension or compression, and not something more complicated.
