timmermeier
- alton il
- electrician
I WANT TO DRILL 1" HOLES IN A 2" X 8" FLOOR JOIST 6" APART 3" FROM THE BOTTOM OF THE JOIST AND 12" FROM THE END OF JOIST, HOW MANY CAN I DRILL IN A JOIST ?
THAT IS NOT WHAT I ASK. AS A INSPECTOR YOU SHOULD KNOW THIS !!!!!!!!!That's a building code question.
Ron
You were given the correct answer and quit yellingTHAT IS NOT WHAT I ASK. AS A INSPECTOR YOU SHOULD KNOW THIS !!!!!!!!!
I think you have it a little wrong, Larry.Generally speaking, you may drill through the center third in both directions.
That works for your 3" up from the bottom, but not your 12" in from one end.
I've read in some official building code spec that holes have to be "3 diameters apart" but I would have to search and find that.I think that with the spacing he proposed, the OP's answer is "as many as will fit", limited by the length of the beam.
I've seen I-joist manufacturers probit holes in the outer third, but your image cannot be one of those because you can't notch anything on an I-joistI'm finding different answers. Here's just one:
