When you install a home standby generator, ther is a ground lug installed on the metal enclosure. The manufacturer states in the installation instructions that you have to install a ground rod next to the generator and ground the enclosure to the ground rod. I have been told by local inspectors that the generator cabinet must be tied to the ground/neutral buss in the main electrical panel so all grounds are common. Which is correct? Please quote section of NEC.
[ March 14, 2005, 07:15 AM: Message edited by: arpech ]
