drcampbell
- The Motor City, Michigan USA
- Registered Professional Engineer
That's a good suggestion. Need not be Onan-specific.... Maybe a muffler off a motor home generator (Onan)
Or an oval muffler for a permanently-installed residential standby generator.
Try to find one whose inlet & outlet diameters are similar to the diameter of the engine's exhaust port.
It will not harm an engine. Reducing back pressure might make the air-fuel ratio too lean if the carburettor is a simple, primitive design that doesn't have much dynamic range.... determine if the difference in back pressure hurts my engines. ...
