growler
- Atlanta,GA
First off I don't pick on home inspectors as most do a fairly good job.
MY question is this. Do you think that a home inspector should have noticed the lack of a main breaker in a service panel? No exterior disconnect.
The panel is main lug, with about 26 total breakers and no overcurrent protection. The panel is cocked about 1" inch with the top being flush and the bottom hanging out of the wall a good deal. All knockouts punched and not sealed ( they must have thought they were for ventilation ) and no connectors used (none) and most of the double pole breakers the wrong size. This should have given a clue their might be a few things wrong. The whole thing is obvious hack work.
The only electrical fault noted was a frayed service cable going into meter.
The fact that the service cable runs through the attic unprotected would have been another clue and should have been written up because it's visable, wouldn't you think?
