Anyone had any experience with this, sounds good but I would appeciate any comments before I decide to try it out.
http://www.power-save.com/1200.html
mlsteele said:...and can compensate for the inductive motor windings resulting in energy savings. Many industrial facility's use large banks of capacitors for the purpose of correcting the power factor and saving on the utility bill.
The product you are looking at is a small bank of capacitor used for the purpose of correcting power factor and their for resulting in a lower utility bill.
Electric rates will go up on average but usage will be less. The end user will reduce lighting power requirements by about 50%.wptski said:What happens if/when we have to switch to all CFL's that have a poor power factor?
If industry has to pay extra for poor power factor, what makes you think that we won't? How long do you think they'll generate 33W for a 18W CFL as an example I've read about? Just seems to be something that seems great right now but later is going turn bad.mivey said:Electric rates will go up on average but usage will be less. The end user will reduce lighting power requirements by about 50%.
I suspect they will eventually make a CF lamp that has a better pf (at a higher price, of course) unless they get overtaken by other technology.
I never realized they were a 60% pf. I just assumed they would be corrected, considering we have higher pf ballasts and all. Just went to GE Lighting and that was their spec.
Who said we won't? We (I'm assuming you mean residential & small commercial users) already pay extra for poor power factor as the costs are embedded in the rates.wptski said:If industry has to pay extra for poor power factor, what makes you think that we won't? How long do you think they'll generate 33W for a 18W CFL as an example I've read about? Just seems to be something that seems great right now but later is going turn bad.
I purchased a few a Home Depot that stated >.9 PF but were really .6!
mivey said:Who said we won't? We (I'm assuming you mean residential & small commercial users) already pay extra for poor power factor as the costs are embedded in the rates.
I don't think they generate 33W for an 18W CFL.
What brand were the CFL from HD? I would like to see how the marketing folks got around the facts. I've got some Bright Effects lamps from Lowes and have had trouble with starting in cold weather and short life. The low power factor is just another thing I can add to the list.
It may not be inconsequential if there is a massive switch to them!Jraef said:The overall effect of power factor from residential users, however massive we may think it is, is in fact inconsequential to the utilities. Their regulation dictates the available power handling their distribution equipment must provide. The fact that there may or may not be poor pf at the residential user's level makes no difference to that, so in effect it isn't worth it to them to bother trying to collect for it, even if they could. Their real delivery cost issues come from large commercial and industrial users who are running a LOT of induction motors. The T&D equipment must be significantly over sized to deal with poor pf, so that directly affects the utilities' costs of doing business. That is why they are allowed to try to offset those costs with penalties.
The poor pf seen from using a CF bulb, or any ballasted system, is primarily distortion power factor, not displacement power factor. There is a difference, especially in the effect it has on the equipment supplying the power. The effects will be in the local pole mounted transformers running hotter (theoretically). Eventually, the increased use of ballasted systems may cause the local transformers to have a slightly shorter life, which means increased replacement frequency etc. etc., but overall, the net effect on consumers will not likely be seen or noticed in anyone's individual lifetime.
I'm more interested in the added mercury that we are now dumping into the environment. I know it is discussed a lot elsewhere and I don't mean to hijack this thread, it's just that to me, pf is not as big a deal to worry about.
vars is vars and the costs will have to be recovered, residential or industrial. The POCOs are allowed to recovered power factor costs from residential and industrial. We don't have a separate penalty on the residential because the load is too small to meter and track these quantities by customer. That is why the var costs for residential are embedded in the rates.Jraef said:The overall effect of power factor from residential users, however massive we may think it is, is in fact inconsequential to the utilities...That is why they are allowed to try to offset those costs with penalties.
Yeah, but when you consider the cost of these power save whiz-bangs, and the attendant costs of having it installed, you're much better off letting the PoCo go ahead and recover those few pennies from you.mivey said:vars is vars and the costs will have to be recovered, residential or industrial. The POCOs are allowed to recovered power factor costs from residential and industrial.
