F fireryan Senior Member Location Minnesota Jun 8, 2016 #1 Do they make a home line main breaker kit to convert a main lug only panel into a main breaker panel. I know they make one for the QO series but can't seem to find anything for homeline
C curt swartz Electrical Contractor - San Jose, CA Location San Jose, CA Occupation Electrical Contractor Jun 8, 2016 #2 If you are asking about the main breaker kits that replace the main lugs, Homeline and QO use the same QOM breakers.
R RLyons Senior Member Location Changed for anonymity Jun 8, 2016 #3 Newer homeline panels you can purchase a separate main breaker and it will bolt right up to the newer MLO. Older panels I'm not sure about.
F fireryan Senior Member Location Minnesota Jun 8, 2016 #4 curt swartz said: If you are asking about the main breaker kits that replace the main lugs, Homeline and QO use the same QOM breakers. Click to expand... Ok I didn't know if homeline made there own model or not
K8MHZ Senior Member Location Michigan. It's a beautiful peninsula, I've looked Occupation Electrician Jun 9, 2016 #5 Or backfeed and use one of these?
electrofelon Senior Member Location Cherry Valley NY, Seattle, WA Occupation Electrician Jun 10, 2016 #6 It is more expensive to buy the main breaker than a new MB panel fyi.
