mkgrady
- Massachusetts
I need to install a MCB in an existing 200 amp MLO panel. It is a Cat# HOMC40UC.
The panel has a knock out where the MCB would go if it had one. I don't have a regular supplier for Square products to ask. So here goes... Purchasing a new 200 MCB panel is only about $100 at the big box. Is it safe to assume that purchasing this panel, removing the MCB and putting it in the existing panel can be done? Is it safe to assume that buying the MCB at a Square D distributor will cost more than $100?
The local Square D supplier charges me substantially more than my other local distributors so I avoid using them.
