Can you use a Square D homeline panel in a commercial space?
Homeline panels are single phase only,so if 3 phase is desired or needed it will be a mismash of panels.
Whereas, the Cutler-Hammer BR line is available in 3-phase.Homeline panels are single phase only,so if 3 phase is desired or needed it will be a mismash of panels.
You should check specs and a h j requirements. One of them may require a panel with bolt ons.
under what grounds does he have the right?
Is this a written amendment?
