- Bremerton, Washington
- Master Electrician
I used a lot of Sq D QO for pump Stations etc. Added a few ckts last week to a Homeline panel. What is the difference between QO and Homeline?
Homeline and QO will not interchange, totally different buss. It’s like Eaton’s CH and BR line, CH is better quality, but is not interchangeable with the BR line.What is the cost for breakers? I am assuming the guts are the same, of course homeline does noy have visi trip
I am nearly certain that it has been confirmed that the homeline and qo guts are the same. IIRC that has come directly from sq D.The QO’s are physically smaller, so I reckon they could put the internals in the larger Homeline frame? Never took one apart to see if they are similar. I know with the Eaton CH, they will trip quicker on a fault than the BR, and the BR is actually a Westinghouse design, so I know Eaton didn’t use the same guts.
They don't, why makes you now think they do?I could’ve swore they definitely do not interchange. Homeline has a buss shaped like GE?
I’ve been using QO in my residential projects exclusively for years, but I’m seeing that everyone else is offering AFCI and GFCI breakers in a smaller form factor, and idk why square D can’t do the same. I’ve been looking seriously at switching to the Eaton BR line for residential. The cost difference is significant.
I’ve been using a mix of Eaton and Square D on my commercial jobs, and Eaton has been much more competitive on price lately by a significant margin. My main supplier is an Eaton dealer, and that has been extremely beneficial in clutch situations.
Sorry , guess I misunderstood, thought y’all were saying the guts are the same?They don't, why makes you now think they do?
Yes the guts are the same, but the case and the stab and mounting is different.Sorry , guess I misunderstood, thought y’all were saying the guts are the same?
Ok thanks. I’ll have to take a closer look next time I run into one.Yes the guts are the same, but the case and the stab and mounting is different.
The Long form factor on the AFCI's does annoy me, I have almost switched to something else for resi because of this.
I really hate BR, I would think twice about it. Not the breakers necessarily, but the loadcenters just seem so flimsy and cheap, plus the cabinets are not painted. Just seems like bottom of the line junk to me. Also some BR MB loadcenters only have 10k MB.
I call the Eaton BR "Zinsco II" , but then I have hated Bryant (it's original brand name) for 40 years, CH is my preferred line.
You will need to disassemble breakers to see the parts that are the same. Nothing on the outside will be the same.Ok thanks. I’ll have to take a closer look next time I run into one.
