hardworkingstiff
- Wilmington, NC
I need a way to check whether the watt-hour meters on marina power pedestals are working. The way I figure it should be done is to put a load on the receptacle and a jumper on the testing terminals of the meter terminal (this jumper changes the counter by a factor of 100).
Now, the problem is how to put a (controlled) load on the receptacle. I could spend 5-10 thousand dollars on a load bank, but I don't know if there will be enough of a payback. What I was kicking around is mounting water heater elements in a box that will float and placing the box (with elements down) into the waterway. I'm thinking at max I will need 4 elements (4500-watt). I can control how many elements I want on at the same time, thereby controlling the load.
My question to the great thinkers on this forum is: What safety issues do you think I will incur?
