Homeowner, DIY NEC questions
Tra
New member
I am rewiring my house after a copper theft, and have a few questions about what's legal and what isn't.
I bought a great book from Home Depot that gives a simplified explanation of the NEC, but there are some items missing.
In the breaker panel, there are holes into which romex clamps allow wires to be passed into the panel. I believe the proper name is 'clamp connector for NM cable'. I need to know if it's ok to run as many wires as the clamp allows (physically), or whether the number of wires/cables is limited?
Also, some NM type cables are run through holes in the floor joists. Am I allowed to run many cables through the same hole, or is there a limit to the number of cables that can be run through a single hole?
Can multiple romex cables be secured by the same staple, or must there only be one cable per staple??? I am aware that I can't bundle or enclose the cable run without de-rating the current rating of the cables.
Also, I need to know if insulated staples must be used or whether I can buy the much cheaper standard type?
Please note, I am (obviously) not an electrician. I would very much like to hire an electrician to do the job, but our home insurance is not covering the copper theft, so I am forced to do my own wiring-nearly 100 percent of the copper cables were stolen by the thieves. I have some knowledge of electronics, but no formal electricians training.
Thanks,
T
I am closing this thread, in accordance with the Forum?s rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation, troubleshooting, or repair work.
I would encourage you to stick around. This Forum has much to offer.
Charles E. Beck, P.E.
