goldstar
- New Jersey
- Electrical Contractor
I was installing ground rods for a service upgrade yesterday and wanted to bury the # 6 under the mulch and along the base of the house. I thought I'd route the wire behind this very neatly installed PVC conduit :
At first glance it looked as though the conduit went directly into the house. When I attempted to pass the wire behind I found this :
And then I found that it went to this about 10' away :
I can't imagine what I'll find when I actually upgrade the breaker panel inside the garage. And the NEC says you can't use THHN for direct burial !!! This has been in place for at least 10 years. You can't make this stuff up. :slaphead:
